A couple of the earlier tutorials seemed to work fine. Then I got to this one.
Running the “animations” example from:
https://circuitmess.com/resources/guides/en/cb-nibble/cb-nibble-2-5
I get the expected green ball that moves down and purple ball that moves up, but after 1-2 bounces, the entire unit just spontaneously resets. I get another 1-2 bounces and a reset. Endlessly.
Peeking behind the LCD I can see the blue LED lit dimly while the animation is running (or flashing very quickly, maybe) then a bright flash upon every reset.
// cm:esp8266:nibble
#include <Arduino.h>
#include <CircuitOS.h>
#include <Nibble.h>
int i;
Display* display;
Sprite* sprite;
void setup() {
Nibble.begin();
display = Nibble.getDisplay();
sprite = display->getBaseSprite();
void loop() {
for (i = 30; i <= 120; i++) {
sprite->clear(TFT_WHITE);
sprite->fillCircle(80, i, 15, TFT_GREEN);
display->commit();
for (i = 120; i >= 30; i--) {
sprite->fillCircle(80, i, 15, TFT_PURPLE);
display->commit();
Hey, thank you for supporting our work and pointing out this potential issue.
We are a bit booked at the moment with other projects, but I’ll take a look into this as soon as possible with the rest of the team and come back with a response.
Thank you
