Hi There,
after i“ve flashed the nibble with micropython. The Screen is cutoff and flickering.
I will add a picture to show. After restoring the Firmware everything works fine again. Any ideas?
Hi There,
ok my bad. I selected the red instead of the yellow version
but what about the flickering?
Hi! If your screen is flickering and it is still flickering after flashing the original code it probably means that your screen is broken and you will need to contact circuitmess for a replacement.
Hey @Jonas_Blochinger,
please try switching display drivers on your Nibble.
You do that by holding Menu button pressed. Youāll see a pop up message saying āHold Menu button pressed to switch the driversā. Keep it pressed and your Nibble should restart with a normal screen.
Let me know if this helped,
