No signal.. what am I doing wrong?
Just received my preassembled 4G unit… yey! Charged it for two hours… inserted sim… ran through the setup… everything passed except for sim test 3/3. Updated firmware… factory reset… setup… same thing. Stuck on ā€œloadingā€ on top. Confirmed working T-Mobile sim card. Ting card same issue. Inserted sim exactly as shown by both the built in setup visual and the online get started instructions and confirmed with a few previous posts on this forum. I opened up the phone and inspected and reseated all the parts just to make sure. I’m in an area with strong signal (NYC). I tried using the phone in clear skies, restarted but nothing. 911 works though (sometimes). I successfully restored the firmware from CircuitBlocks but no sim change. I’m stumped.
SIM7600A
T-Mobile
Antenna plugged into top most port.
You have a DM!
Everyone seems to have the same problem, but everyone just talks about going outside or switching services. I haven’t seen one difference in what people are doing. I have done it all and every phone company I talk to say the same thing. No one can get my makerphone to work.
@8bitRobot thanks for joining the forum and supporting our work :slight_smile:
Just to make things clear - not everyone is having signal issues and MAKERphone will work with any carrier if it supports the network bands used by the carrier.
The problems usually arise because of the assembly or some other reasons and they are usually quite unique.
But don’t worry, we’ll help you make your MAKERphone work
@robertCM can you please get in touch with @8bitRobot and help him sort this out?
Don’t worry, we’ll help you make your MAKERphone work :slight_smile:
Thanks
From what I can tell, there hasn’t been much difference between the actual problem and ā€œgenericā€ problems. The Ringo seems to have ā€œloose driversā€. I believe that occurs when multiple C libraries conflict with each other, but anything can set off a driver. There are many big reasons that are simple like inserting the SIM in the wrong side or using the wrong SD card. I’m trying to avoid more complicated solutions like searching through the board or switching out components for kicks. I bought the assembled, so I assumed the majority of problems would be software related. I’m running out on my troubleshooting list for this one.
@8bitRobot I’m not sure what ā€œloose driversā€ means, but we’ve put a lot of effort into making MAKERphone’s software as good as we could and we’re patching it regularly as well.
If you’ve bought the assembled unit, of course you won’t be required to do manual rework or assembly.
Please, just wait for Robert’s instructions on how to fix this issue, he’ll help you out.
Thank you for your patience
Sorry to see you having problems!
Since you’ve pretty much tried every simple fix, I’m going to have to ask you to give me some more data.
Did you install Arduino IDE drivers for Ringo? I will need to see what does ā€œSerialā€ say when you turn on the phone so we can check out whether is Network board working properly or not.
Are you familiar with the Serial option in the Arduino IDE or do you need a guide?
We’ll sort this out. :smiley:
I just saw your post. I didn’t install drivers yet. I’ll take a look at it.
NO CARRIER
15:46:01.420 -> AT+CSQ
15:46:01.420 -> +CSQ: 99,99
15:46:01.420 ->
15:46:01.420 -> OK
15:46:01.420 -> --------------
15:46:01.420 ->
15:46:01.420 ->
15:46:02.707 -> --------------
15:46:02.707 -> A
15:46:02.741 -> --------------
15:46:02.741 -> AT
15:46:02.775 -> --------------
15:46:02.775 -> AT+
15:46:02.775 -> AT+C
15:46:02.809 -> --------------
15:46:02.809 -> AT+CR
15:46:02.809 -> AT+CRE
15:46:02.842 -> --------------
15:46:02.842 -> AT+CREG
15:46:02.842 -> AT+CREG?
15:46:02.876 -> --------------
15:46:02.876 -> AT+CREG?
15:46:02.910 -> --------------
15:46:02.910 -> AT+CREG?
15:46:02.910 ->
15:46:02.910 -> +
15:46:02.943 -> --------------
15:46:02.943 -> AT+CREG?
15:46:02.943 -> +C
15:46:02.943 -> +CR
15:46:02.977 -> --------------
15:46:02.977 -> AT+CREG?
15:46:02.977 -> +CRE
15:46:02.977 -> +CREG
15:46:03.011 -> --------------
15:46:03.011 -> AT+CREG?
15:46:03.011 -> +CREG:
15:46:03.056 -> --------------
15:46:03.056 -> AT+CREG?
15:46:03.056 -> +CREG: 0
15:46:03.056 -> +CREG: 0,
15:46:03.056 -> +CREG: 0,2
15:46:03.103 -> --------------
15:46:03.103 -> AT+CREG?
15:46:03.103 -> +CREG: 0,2
15:46:03.103 ->
15:46:03.103 ->
15:46:03.150 -> --------------
15:46:03.150 -> AT+CREG?
15:46:03.150 -> +CREG: 0,2
15:46:03.150 ->
15:46:03.150 ->
15:46:03.150 ->
15:46:03.150 -> O
15:46:03.197 -> --------------
15:46:03.197 -> AT+CREG?
15:46:03.197 -> +CREG: 0,2
15:46:03.197 ->
15:46:03.197 -> OK
15:46:03.197 ->
15:46:03.197 -> OK
15:46:03.197 ->
15:46:03.197 ->
15:46:04.791 -> --------------
15:46:04.791 -> A
15:46:04.791 -> AT
15:46:04.838 -> --------------
15:46:04.838 -> AT+
15:46:04.838 -> AT+C
15:46:04.838 -> AT+CR
15:46:04.885 -> --------------
15:46:04.885 -> AT+CRE
15:46:04.885 -> AT+CREG
15:46:04.885 -> AT+CREG?
15:46:04.932 -> --------------
15:46:04.932 -> AT+CREG?
15:46:04.979 -> --------------
15:46:04.979 -> AT+CREG?
15:46:04.979 ->
15:46:04.979 -> +
15:46:04.979 -> +C
15:46:05.026 -> --------------
15:46:05.026 -> AT+CREG?
15:46:05.026 -> +CR
15:46:05.026 -> +CRE
15:46:05.072 -> --------------
15:46:05.072 -> AT+CREG?
15:46:05.072 -> +CREG
15:46:05.072 -> +CREG:
Lock Screen info
15:48:53.433 -> at printed
15:48:53.735 ->
15:48:53.735 -> -------------
15:48:53.735 ->
15:48:53.735 ->
15:48:53.735 ->
15:48:53.735 -> R
15:48:53.735 ->
15:48:53.735 -> RD
15:48:53.735 ->
15:48:53.735 -> RDY
15:48:53.803 -> ATI
15:48:53.803 -> Manufacturer: SIMCOM INCORPORATED
15:48:53.803 -> Model: SIMCOM_SIM7600A
15:48:53.803 -> Revision: SIM7500A_V1.1
15:48:53.803 -> SVN: 02
15:48:53.803 -> IMEI: 015136000941174
15:48:53.803 -> +GCAP: +CGSM
15:48:53.803 ->
15:48:53.803 -> OK
15:48:53.803 -> checking sim
15:48:53.803 ->
15:48:53.803 -> AT+CPIN?
15:48:53.803 -> +CME ERROR: SIM busy
15:48:53.803 -> printed at+cpin?
15:48:53.803 ->
15:48:53.803 ->
15:48:53.803 ->
15:48:53.803 ->
15:48:53.803 ->
15:48:53.803 ->
15:48:53.837 ->
15:48:53.837 -> AT+CPIN?
15:48:53.837 -> +CME ERROR: SIM busy
15:48:53.837 -> printed at+cpin?
15:48:53.837 ->
15:48:53.837 ->
15:48:53.837 ->
15:48:53.837 ->
15:48:53.837 ->
15:48:53.837 ->
15:48:53.870 ->
15:48:53.870 -> AT+CPIN?
15:48:53.870 -> +CME ERROR: SIM busy
15:48:53.870 -> printed at+cpin?
15:48:53.870 ->
15:48:53.870 ->
15:48:53.870 ->
15:48:53.870 ->
15:48:53.870 ->
15:48:53.870 ->
15:48:53.903 ->
15:48:53.903 -> AT+CPIN?
15:48:53.903 -> +CME ERROR: SIM busy
15:48:53.903 -> printed at+cpin?
15:48:53.903 ->
15:48:53.903 ->
15:48:53.903 ->
15:48:53.903 ->
15:48:53.903 ->
15:48:53.903 ->
15:48:53.903 ->
15:48:53.936 ->
15:48:53.936 -> AT+CPIN?
15:48:53.936 -> +CME ERROR: SIM busy
15:48:53.936 -> printed at+cpin?
15:48:53.936 ->
15:48:53.936 ->
15:48:53.936 ->
15:48:53.936 ->
15:48:53.936 ->
15:48:53.936 ->
15:48:54.003 ->
15:48:54.003 -> AT+CPIN?
15:48:54.003 -> +CME ERROR: SIM busy
15:48:54.003 -> printed at+cpin?
15:48:54.003 ->
15:48:54.003 ->
15:48:54.003 ->
15:48:54.003 ->
15:48:54.003 ->
15:48:54.003 ->
15:48:54.003 ->
15:48:54.003 ->
15:48:54.003 ->
15:48:54.040 ->
15:48:54.040 -> AT+CPIN?
15:48:54.040 -> +CME ERROR: SIM busy
15:48:54.040 -> printed at+cpin?
15:48:54.040 ->
15:48:54.040 ->
15:48:54.040 ->
15:48:54.040 ->
15:48:54.040 ->
15:48:54.040 ->
15:48:54.040 ->
15:48:54.040 ->
15:48:54.040 ->
15:48:54.087 ->
15:48:54.087 -> AT+CPIN?
15:48:54.087 -> +CME ERROR: SIM busy
15:48:54.087 -> printed at+cpin?
15:48:54.087 ->
15:48:54.087 ->
15:48:54.087 ->
15:48:54.087 ->
15:48:54.087 ->
15:48:54.087 ->
15:48:54.087 ->
15:48:54.087 ->
15:48:54.087 ->
15:48:54.087 ->
15:48:54.133 ->
15:48:54.133 -> AT+CPIN?
15:48:54.133 -> +CME ERROR: SIM busy
15:48:54.133 -> printed at+cpin?
15:48:54.133 ->
15:48:54.133 ->
15:48:54.133 ->
15:48:54.133 ->
15:48:54.133 ->
15:48:54.133 ->
15:48:54.133 ->
15:48:54.133 ->
15:48:54.133 ->
15:48:54.133 ->
15:48:54.180 ->
15:48:54.180 -> AT+CPIN?
15:48:54.180 -> +CME ERROR: SIM busy
15:48:54.180 -> printed at+cpin?
15:48:54.180 ->
15:48:54.180 ->
15:48:54.180 ->
15:48:54.180 ->
15:48:54.180 ->
15:48:54.180 -> +CPIN: READY
15:48:54.180 ->
15:48:54.180 -> OK
15:48:55.165 -> SD inserted
15:48:55.212 ->
15:48:55.212 -> airplane_mode: 0
15:48:55.212 -> brightness: 3
15:48:55.212 -> sleep_time: 0
15:48:55.212 -> background_color: 4
15:48:55.212 -> notification: 1
15:48:55.212 -> ringtone: /Ringtones/retro_nokia2.wav
15:48:55.305 -> CFUN checking
15:48:55.305 -> AT+CFUN?
15:48:55.305 -> +CFUN: 1
15:48:55.305 ->
15:48:55.305 -> OK
15:48:55.305 -> next alarm: 0
15:48:55.305 -> module inserted
15:48:55.305 -> SIM INSERTED
15:48:55.399 -> Serial1 up and running…
15:48:55.399 -> Setup: 0
15:48:55.399 -> --------------
15:48:55.399 ->
15:48:55.432 -> --------------
15:48:55.432 ->
15:48:55.432 ->
15:48:55.432 ->
15:48:55.466 -> --------------
15:48:55.466 ->
15:48:55.466 ->
15:48:55.466 ->
15:48:55.466 -> P
15:48:55.499 -> --------------
15:48:55.499 ->
15:48:55.499 -> PB
15:48:55.533 -> --------------
15:48:55.533 ->
15:48:55.533 -> PB
15:48:55.533 ->
15:48:55.533 -> PB D
15:48:55.533 ->
15:48:55.533 -> PB DO
15:48:55.566 -> --------------
15:48:55.566 ->
15:48:55.566 -> PB DON
15:48:55.566 ->
15:48:55.566 -> PB DONE
15:48:55.599 -> --------------
15:48:55.599 ->
15:48:55.599 -> PB DONE
15:48:55.636 -> --------------
15:48:55.636 ->
15:48:55.636 -> PB DONE
15:48:55.636 ->
15:48:55.636 ->
15:48:55.636 -> A
15:48:55.636 ->
15:48:55.636 -> AT
15:48:55.683 -> --------------
15:48:55.683 ->
15:48:55.683 -> PB DONE
15:48:55.683 -> AT+
15:48:55.683 ->
15:48:55.683 -> AT+C
15:48:55.683 ->
15:48:55.683 -> AT+CR
15:48:55.727 -> --------------
15:48:55.727 ->
15:48:55.727 -> PB DONE
15:48:55.727 -> AT+CRE
15:48:55.727 ->
15:48:55.727 -> AT+CREG
15:48:55.773 -> --------------
15:48:55.773 ->
15:48:55.773 -> PB DONE
15:48:55.773 -> AT+CREG?
15:48:55.773 ->
15:48:55.773 ->
15:48:55.820 -> --------------
15:48:55.820 ->
15:48:55.820 -> PB DONE
15:48:55.820 -> AT+CREG?
15:48:55.820 ->
15:48:55.820 ->
15:48:55.820 -> +
15:48:55.820 ->
15:48:55.820 -> +C
15:48:55.867 -> --------------
15:48:55.867 ->
15:48:55.867 -> PB DONE
15:48:55.867 -> AT+CREG?
15:48:55.867 -> +CR
15:48:55.867 ->
15:48:55.867 -> +CRE
15:48:55.914 -> --------------
15:48:55.914 ->
15:48:55.914 -> PB DONE
15:48:55.914 -> AT+CREG?
15:48:55.914 -> +CREG
15:48:55.914 ->
15:48:55.914 -> +CREG:
15:48:55.914 ->
15:48:55.961 -> --------------
15:48:55.961 ->
15:48:55.961 -> PB DONE
15:48:55.961 -> AT+CREG?
15:48:55.961 -> +CREG: 0
15:48:55.961 ->
15:48:55.961 -> +CREG: 0,
15:48:56.008 -> --------------
15:48:56.008 ->
15:48:56.008 -> PB DONE
15:48:56.008 -> AT+CREG?
15:48:56.008 -> +CREG: 0,2
15:48:56.008 ->
15:48:56.008 ->
15:48:56.008 ->
15:48:56.055 -> --------------
15:48:56.055 ->
15:48:56.055 -> PB DONE
15:48:56.055 -> AT+CREG?
15:48:56.055 -> +CREG: 0,2
15:48:56.055 ->
15:48:56.055 ->
15:48:56.055 ->
15:48:56.055 ->
15:48:56.102 -> --------------
15:48:56.102 ->
15:48:56.102 -> PB DONE
15:48:56.102 -> AT+CREG?
15:48:56.102 -> +CREG: 0,2
15:48:56.102 ->
15:48:56.102 -> O
15:48:56.102 ->
15:48:56.102 ->
15:48:56.102 -> OK
15:48:56.148 -> --------------
15:48:56.148 ->
15:48:56.148 -> PB DONE
15:48:56.148 -> AT+CREG?
15:48:56.148 -> +CREG: 0,2
15:48:56.148 ->
15:48:56.148 -> OK
15:48:56.148 ->
15:48:56.148 ->
15:48:57.517 -> --------------
15:48:57.517 -> A
15:48:57.517 -> AT
15:48:57.550 -> --------------
15:48:57.550 -> AT+
15:48:57.550 -> AT+C
15:48:57.584 -> --------------
15:48:57.584 -> AT+CR
15:48:57.584 -> AT+CRE
15:48:57.619 -> --------------
15:48:57.619 -> AT+CREG
15:48:57.619 -> AT+CREG?
15:48:57.654 -> --------------
15:48:57.654 -> AT+CREG?
15:48:57.701 -> --------------
15:48:57.701 -> AT+CREG?
15:48:57.701 ->
15:48:57.701 -> +
15:48:57.701 -> +C
15:48:57.748 -> --------------
15:48:57.748 -> AT+CREG?
15:48:57.748 -> +CR
15:48:57.748 -> +CRE
15:48:57.748 -> +CREG
15:48:57.795 -> --------------
15:48:57.795 -> AT+CREG?
15:48:57.795 -> +CREG:
15:48:57.841 -> --------------
15:48:57.841 -> AT+CREG?
15:48:57.841 -> +CREG: 0
15:48:57.841 -> +CREG: 0,
15:48:57.841 -> +CREG: 0,2
15:48:57.888 -> --------------
15:48:57.888 -> AT+CREG?
15:48:57.888 -> +CREG: 0,2
15:48:57.888 ->
15:48:57.888 ->
15:48:57.935 -> --------------
15:48:57.935 -> AT+CREG?
15:48:57.935 -> +CREG: 0,2
15:48:57.935 ->
15:48:57.935 ->
15:48:57.935 ->
15:48:57.935 -> O
15:48:57.982 -> --------------
15:48:57.982 -> AT+CREG?
15:48:57.982 -> +CREG: 0,2
15:48:57.982 ->
15:48:57.982 -> OK
15:48:57.982 ->
15:48:57.982 -> OK
15:48:57.982 ->
15:48:57.982 ->
15:48:59.572 -> --------------
15:48:59.572 -> A
15:48:59.572 -> AT
15:48:59.605 -> --------------
15:48:59.605 -> AT+
15:48:59.605 -> AT+C
15:48:59.639 -> --------------
15:48:59.639 -> AT+CR
15:48:59.639 -> AT+CRE
15:48:59.673 -> --------------
15:48:59.673 -> AT+CREG
15:48:59.673 -> AT+CREG?
15:48:59.706 -> --------------
15:48:59.706 -> AT+CREG?
15:48:59.741 -> --------------
15:48:59.741 -> AT+CREG?
15:48:59.741 ->
15:48:59.741 -> +
15:48:59.775 -> --------------
15:48:59.775 -> AT+CREG?
15:48:59.775 -> +C
15:48:59.775 -> +CR
15:48:59.809 -> --------------
15:48:59.809 -> AT+CREG?
15:48:59.809 -> +CRE
15:48:59.809 -> +CREG
15:48:59.842 -> --------------
15:48:59.842 -> AT+CREG?
15:48:59.842 -> +CREG:
15:48:59.875 -> --------------
15:48:59.875 -> AT+CREG?
15:48:59.875 -> +CREG: 0
15:48:59.910 -> --------------
15:48:59.910 -> AT+CREG?
15:48:59.910 -> +CREG: 0,
15:48:59.910 -> +CREG: 0,2
15:48:59.943 -> --------------
15:48:59.943 -> AT+CREG?
15:48:59.943 -> +CREG: 0,2
15:48:59.943 ->
15:48:59.943 ->
15:48:59.978 -> --------------
15:48:59.978 -> AT+CREG?
15:48:59.978 -> +CREG: 0,2
15:48:59.978 ->
15:48:59.978 ->
15:49:00.012 -> --------------
15:49:00.012 -> AT+CREG?
15:49:00.012 -> +CREG: 0,2
15:49:00.012 ->
15:49:00.012 -> O
15:49:00.012 ->
15:49:00.012 -> OK
15:49:00.053 -> --------------
15:49:00.053 -> AT+CREG?
15:49:00.053 -> +CREG: 0,2
15:49:00.053 ->
15:49:00.053 -> OK
15:49:00.053 ->
15:49:00.053 ->
15:49:01.605 -> --------------
15:49:01.605 -> A
15:49:01.652 -> --------------
15:49:01.652 -> AT
15:49:01.652 -> AT+
15:49:01.652 -> AT+C
15:49:01.699 -> --------------
15:49:01.699 -> AT+CR
15:49:01.699 -> AT+CRE
15:49:01.699 -> AT+CREG
15:49:01.746 -> --------------
15:49:01.746 -> AT+CREG?
15:49:01.793 -> --------------
15:49:01.793 -> AT+CREG?
15:49:01.793 ->
15:49:01.793 -> +
15:49:01.840 -> --------------
15:49:01.840 -> AT+CREG?
15:49:01.840 -> +C
15:49:01.840 -> +CR
15:49:01.840 -> +CRE
15:49:01.887 -> --------------
15:49:01.887 -> AT+CREG?
15:49:01.887 -> +CREG
15:49:01.887 -> +CREG:
15:49:01.934 -> --------------
15:49:01.934 -> AT+CREG?
15:49:01.934 -> +CREG:
15:49:01.934 -> +CREG: 0
15:49:01.934 -> +CREG: 0,
15:49:01.980 -> --------------
15:49:01.980 -> AT+CREG?
15:49:01.980 -> +CREG: 0,2
15:49:01.980 ->
15:49:02.027 -> --------------
15:49:02.027 -> AT+CREG?
15:49:02.027 -> +CREG: 0,2
15:49:02.027 ->
15:49:02.027 ->
15:49:02.027 ->
15:49:02.074 -> --------------
15:49:02.074 -> AT+CREG?
15:49:02.074 -> +CREG: 0,2
15:49:02.074 ->
15:49:02.074 -> O
15:49:02.074 ->
15:49:02.074 -> OK
15:49:02.074 ->
15:49:02.074 -> OK
15:49:02.121 -> --------------
15:49:02.121 ->
15:49:02.121 ->
15:49:03.664 -> --------------
15:49:03.664 -> A
15:49:03.710 -> --------------
15:49:03.710 -> AT
15:49:03.710 -> AT+
15:49:03.710 -> AT+C
15:49:03.757 -> --------------
15:49:03.757 -> AT+CR
15:49:03.757 -> AT+CRE
15:49:03.757 -> AT+CREG
I see that your CSQ is 99 at the beginning - it means that something is possibly either not connected properly or broken from the components that are trying to connect to the network.
That is probably the reason that you cannot get the signal.
Can you please go to the Settings -> About & Update -> SIM Module Debug, so we can see if the phone recongises any carriers?
It does. I’ll c+p it.
14:05:17.305 -> +COPS: (1,ā€œT-Mobileā€,ā€œT-Mobileā€,ā€œ310260ā€,7),(1,ā€œAT&Tā€,ā€œAT&Tā€,ā€œ310410ā€,2),(1,ā€œVerizonā€,ā€œVerizonā€,ā€œ311480ā€,7),(1,ā€œAT&Tā€,ā€œAT&Tā€,ā€œ310410ā€,7),(1,ā€œ313 100ā€,ā€œ313 100ā€,ā€œ313100ā€,7),(0,1,2,3,4,5),(0,1,2)
Whose SIM card are you trying to use?
This shows that the module is doing its job of finding the networks, now it’s just a problem of connecting to them.
TMobile. Brand new too. Just went to the shop when I got it.
I seem to have the same exact problem as the poster. However, you privately messaged him. Did he get his Ringo to work? If not, I may never get service.
Edit- Nvm. I’m going to say that the problem is different…probably.
(post deleted by author)
That’s not good…maybe I’ll take it apart or something. I’ll update you if mine ever works.
The phone companies are blaming the phone, and then they blame my location. They literally couldn’t get it to work in person.
The only thing I can say is signal. I got 15/100. It’s enough to initiate a call, but not reach the destination. How many bars did you get when you read?
Hey @royjr96,
You can still sending to us using any other post office, there is no problem with that!
We’re still going to repair it for you free of charge and return it, we just cannot pay the bill of you shipping it to us.
This deal with DHL was a thing we’re doing to make this whole thing of repairing the device completely free for our customers. We just cannot make deal with every shipping company in the world so we did it with one that covers pretty much everything.
Sorry if you feel that way about Ringo, but we can always fix the problem and send it back to you. Feel free to send it any way you can at any time.
@8bitRobot If there is a signal, that means that it works. The strength of the signal is not something that we can affect in any way. Everything works great for the vast majority of our customers so I guess it must be either a hardware or a network problem.
And since you’re getting at least some signal, that means that the hardware is functional.
Of course we’re still trying to get to the bottom of this since every customer is important for us, but every case is so specific that we just don’t have an immediate solution for everyone. :confused:
