@mrded, thank you for supporting MAKERbuino and welcome to the forum.
Please go back to build guide chapter #3 and slowly go through the steps again:
You are missing a voltage regulator, the device cannot work without that component.
What missing screws are you referring to?
If you’re talking about the small screws used for fastening the screen (M2), you should only have two of those.
Please examine the full list of components here:
Please examine the photo from the last post, you only need two M2 screws and the console was designed in a way that the screen is fixed only using two M2 screws via the two bottom holes.
This was also explained here: https://www.makerbuino.com/build-3-soldering-time-starts-now/
