It has been working fine and made a game for it since putting it together. But after leaving it alone for a few weeks this started happening…
I haven’t touched it for a long time, I’ve tried recharging but it seems to make the situation worse as sometimes it doesn’t display anything at all…
Any suggestions?
Thanks in advance!
Nevermind, I’ve solved the problem:
All I did to fix it was to unplug the battery from the board, then switch it on to ‘flush’ any remaining power from the capacitors and other components. Then I plugged the battery back in to the board and powered it on. Works perfectly now.
Do as you wish with this topic, I was thinking about removing it but I thought that if anyone else has this problem then they can find this fix.
Thanks for reading anyway
@Craig_Page, I am not quite sure what caused this issue but I’m glad that you’ve managed to fix it.
Cheers!
