Hello everyone, greetings from Greece.
So today I received my Spencer and decided right on to get onto it. Even though I have zero prior experience with soldering, in a just a couple hours Spencer was ready for Circuitblocks. Great packaging, solid instructions, generally an interesting experience, recommended for any age. (Im 26)
A few notes
Soldering pen - [I have the one with the blue light and manual button] I initially connected it to my laptop (through a USB hub) but while soldering I would notice, probably because the iron was not heated enough, that a small quantity of soldering tended to accumulate on the needle, thus making the iron unusable - I had to regularly use a knife to clean the needle of the soldering. At the end I used a 40W iron I had from my Father’s lab and everything went smoothy from that point. Maybe if I had connected it directly to a power supply it would be enough.
Big red button - If you turn or flip Spencer, the button will fall off. A workaround I found was using a little bit of superglue with a stick and now its solid.
Circuitblocks App - [Installed on a Mac OS Catalina 10.15.7] Installation was stuck while on Arduino installation, forced closed the app and it ended up finishing smoothy.
Spencer is not available yet in the projects, so I just changed the settings on the top right corner. Added the SSID and the password, but unfortunately Spencer hasn’t connected and neither does anything when I press the red button.
The light panel is working normally, though the red light is inoperative when I press the red button.
Any solution on how to make Spencer work?
Also, what does the small button do on the back? Is it like a forced restart or reset?
Thanks,
Paul
Update: Spencer lights after 10 minutes of use stuck in a shape, decided to remove the power cable and re-insert and now it doesn’t start at all…
