So I am trying to connect the MakerBuino to the Arduino IDE. I am getting the “USB device not recognized…” on the Windows 10 computer. The green light on the UART is on. The IDE doesn’t display any PORT. The computer is recognizing that I have a USB device, but that’s as far as I have gotten with the MakerBuino and the IDE.
Strangely enough, hubby also bought a SNAPINO. The computer sees that device just fine.
What gives? This is very frustrating.
NoraLee in Northern Jersey
Try to download and install the Win10 driver of the UART-to-USB chip. It should have a description or model number printed on it. I’d give you a link but I’m currently at work and I don’t have the adapter with me
*€dit: @Noralee9 I’ve found the link to the driver
Please download and install them and let us know if it fixed your problem
http://www.ftdichip.com/Drivers/CDM/CDM%20v2.12.28%20WHQL%20Certified.zip
Here are my tested solutions if your device is not recognizing USB.
Solution 1: Restart the system
Solution 2: Remove the other USBs
Solution 3: Turn the Fast Startup off
Solution 4: Uninstall the Hidden Devices
Solution 5: Update the cp2102 Drivers
I am sure these fixes will sure fix your usb device not recognized problem.
