Bootloader, loading from SD etc..? [SOLVED]
I’m not new to Arduino, but new to Makerbuino. I soldered everything up and it works great. I do have a few questions though.
  1. What bootloader is ATMega flashed with? Is it a special bootloader? I assume the ATMega that came with the kit was flashed perhaps with a special bootloader and/or with a special sketch. If I was to replace the ATMega chip down the road, what would I need to flash a new blank ATMega chip with in order to get it to work in the MakeBurino?
  2. How does the MakeBurino flash games from the SD? I only know how to flash from the Arduino IDE. I am familiar with reading a writing to an SD, SPI, I2c etc… but I didn’t know that you could flash from an SD.
Any insight would be appreciated. I’m just trying to understand how it works.
By the way, my build turned out great and I really like the way it looks. Well worth the time and money in my opinion.
The buttons are little noisy and the menu sketch needs debounce added. Once I figure out what scripts are being used, I’ll modify the menu script and add debounce to the buttons.
If you will buy new Atmega chip, you will have to flash the bootloader. You can find the link somewhere in the forum. I did it my self. Depending on the way you are going to flash it, do not forget to set correct fuse and lock bits. Maker buino, Flash games from sd card to eeprom.
Hey @bkahuna,
MAKERbuino is using a special bootloader that was based on optiboot (a bootloader that Arduino boards use).
Yes, you can flash programs from an SD card just as you would flash it via ISP or TTL.
ATmega328 is self-programmable, meaning that it can read a stream of data from an SD card (i.e. a HEX file stored on an SD card) and modify its own flash memory.
The bootloader is the part of the flash memory that is not edited and is responsible for self-programming of the microcontroller.
You can find the bootloader here:
https://www.makerbuino.com/wp-content/uploads/2018/07/MAKERbuino.zip
Also, you can read more about it here:
http://legacy.gamebuino.com/wiki/index.php?title=Bootloader
If you were to replace your ATmega, the easiest way to flash it would be using Arduino IDE + USBasp board from ebay (costs USD5).
You can find more about bootloader flashing here:
https://learn.sparkfun.com/tutorials/installing-an-arduino-bootloader
I hope this helps and I am really glad that your build works :slight_smile:
Please, share some photos of your build here:
See you around!
hey Albert,
this boot loader is no longer on this site
can you send me it, because I want to make this console
Hey Mikolaj,
Here is the link where you can find everything you need for MAKERbuino - https://circuitmess.com/resources/guides/en/resources/useful-links.
Hi, I was not able to use the link to download the firmware from the link
Hey @naytik_alijar,
thank you for reaching out.
You are looking for MakerBuino firmware?
-Monika
Yes @Monika_Tomljanovic
I am having trouble flashing the firmware on using the latest version of arduino ide
Hey @naytik_alijar,
here is the file with the MakerBuino firmware.
Let me know if you need any help,
MAKERbuino.zip (81.7 KB)
