i realised that i also burnt the diode on the black side
i was thinking of connecting it to this pin and keeping the wire down with hot glue
would this work?
Yes that will work, the only problem I see is that hole is VERY close to the live wire of the speaker, you’ll need to be careful to not bridge that connection when soldering in the wire as it will potentially damage components when the speaker turns on.
P.S. You do not need to make a second post for follow-up problems, we’ll see your new post in the old one.
thanks for telling me, but i will be soldering it from the top so there is less chance of a bridge.
I just finished soldering and it worked well, thanks for the help!
(You can mark this as solved)
I’ve marked this topic as Solved…
