Ok guys, this is pretty embarrasing… But tonight I started triple checking everything, desoldered a bunch of components to make sure they were correct and… Well, turns out one of the pins on my ATMEGA socket was bent when I put it inthe first time, and so, wasn’t soldered properly… I had to desolder the entire socket and take it out to fix the pin (what a nightmare). Good thing is that my Makerbuino now works! Yay!
Okay @bitfogav , here’s my recordings based on what you asked me to provide:
8 7 - 3.29v
8 1 - 3.26v
22 21 - 3.29v
22 20 - 3.29v
screen - 3.92v
I also tried putting the micro controller back in again (checking all pins) but no luck.
Thanks.
Hi @bitfogav
Just tagging you again in case you missed my last msg containing the voltages. Appreciate you’re busy so just making sure.
Thanks.
@tommyph1208 great stuff, glad you got your makerbuino working
@amilanvega Sorry for getting back to you late but I’m back at work this week so don’t get much time.
You’re voltage results are perfect!, shows your microprocessor and screen have got power and grounds.
I’ve had another look at you’re makerbuino images and I can’t see anything wrong. The only thing I cant see is the solder joints underneath the screen for the microprocessor connector?.
Can you remove the screen and check the solder joints and double check all the other solder joints too, if you have too maybe run the soldering iron over them all again with some solder just to make sure?.
The only other things that are left is the connections between the microprocessor data lines and the screen, or even the software loaded onto the microprocessor?.
But there is also the possibility that after all this the microprocessor or screen could be faulty.
Thanks again, @bitfogav.
I’ve taken some more detailed pics of the soldering points without the screen attached:
https://photos.app.goo.gl/YcmVTWsb8rqnbW9f1
What would then be my options for testing the connections between the MP data lines/screen, the software, the MP itself or the screen itself?
Lots of people seem to be posting on the forum saying that MakerBuino’s contact is very bad.
Thanks for the images. Looking at the one with the pic connector, this solder joint doesn’t look right?
My first build Saturday evening went well, failing around 20 hours later. This was rectified with the C button. However, I have built my second unit tonight, and it does not boot up. Voltages to the micro and LCD are good. However, there is no 16MHz sine wave on each side of the crystal on this non-functional board. The working board has a nice 16MHz sine wave on each side of the crystal.
It would appear that my microcontroller is not functional, or maybe not programmed.
You could try putting the ATMEGA chip into the other unit, this way you can ensure the chip is functioning. My best guess would be the crystal component itself is broken, I’m sure if you ask the makerbuino guy he can send you replacements… or you could grab them at a local hardware store.
Swapping the micro over between the working and non working devices was going to be the next thing I try (will do that when I get home tonight). That will tell me if the fault stays with the board, or moves with the micro.
Well, I have some good news and some bad news. the good news is that my second board and components is fine. The bad news is that the microcontroller is faulty. The fault moved with the microcontroller.
I will send an email to Albert and tell him the bad news.
Let Albert know and I’m sure he’ll send you a new one.
@wojtek and @bitfogav, thank you for your effort and helping @amilanvega out!
I really appreciate the effort you’re putting into this and your activity on the community forum.
@tommyph1208, I am really glad that your MAKERbuino is working and would love seeing it work (pics or it didn’t happen
I’ve spoken with @Eddie and will send him a replacement micro this Thursday.
@amilanvega, please don’t give up, we will help you build your MAKERbuino.
What is the status of your build? Have you managed to make something work in the meantime?
Hi! I have the same problem as @amilanvega, only difference is that i have different measurements. My multimeter showed around 2.7v. Is this high enough voltage? Is microcontroler in inventors kit loaded with software or do i have to program it?
The microcontroller SHOULD be loaded with software to at least see something (see screenshot above your post for an example) BUT some microcontrollers have been reported not to be loaded with software on these here forums.
If you have an Arduino Uno you could test your microcontroller and your screen, check out one of my earlier posts:
@Gemberkoekje, correct, there is a certain number of units with blank micros due to a production error we’ve made. I’ve explained the cause of this in this topic:
@tommyph1208, your MAKERbuino is looking super-duper, you’ve just earned a “MAKERbuino maker” badge!
I’ve spoken with @pow33 about the issue. In the end, it turned out that there was a problem with the screen, not the microcontroller.
@amilanvega, we are still waiting for your reply. Please update me with a status of your build
A package arrived in the mail today. It’s my replacement micro.
Thanks for the extras. I really appreciate it. This is just another example of the manufacturer going out of their way to make it right for their customers.
Will try it out tonight, and customise my makerbuino with the extras.
@Eddie, congratulations!
Your MAKERbuino looks super-duper
I am really glad everything works now. You’ve just earned a couple of snazzy badges!
If you need anything else, feel free to send me a message.
@amilanvega, did you manage to make some progress with your build?
